12-07-2016
06:24
10:26
12-07-2016
06:24
10:26
First full day with Charge 2 - love it (although the call center support is -- predictably -- deplorable.
1. I walked what I know is 1.8 miles this morning to work, but the FitBit shows it as 2.7 miles. Is it that inaccurate?
2. How am I supposed to track my walking when "walk" is not an option under the exercise choices on the tracker?
12-07-2016 09:46
12-07-2016 09:46
@SkipII wrote:First full day with Charge 2 - love it (although the call center support is -- predictably -- deplorable.
Fortunately, that has not been my experience. I have received nothing but courteous, professional service from then.
1. This is dependent upon your entered Stride Length. If you set up your profile with your sex, age, height, and weight, it assumed what your stride length would be. If your actual stride length is quite different, the distance calculation will be off by that amount, and you need to manually enter your stride length.
2. You go into the dashboard device settings for Exercise Shortcuts and add Walk if it is not there. Then you can track your walking with Connected-GPS.
Best Answer12-07-2016 11:07
12-07-2016 11:07
12-07-2016 11:07
Best Answer12-07-2016 11:18
12-07-2016 11:18
@SkipII You can add the Walk exercise shortcut on your Charge 2 by following the instructions listed here.
Keep me posted if you need any additional help!
Best Answer12-07-2016 11:29
12-07-2016 11:29
Best Answer12-07-2016 11:38
12-07-2016 11:38
Yes, did that, but how do I get it to show up on the tracker?
Best Answer12-07-2016 12:19
12-07-2016 12:19
On the screen that you used to add tye walk, you are able to reda arange your entries. On the Charge 2 tap the button to get over to exercises. Now tap the display untill walk is showing.
12-07-2016 16:22
12-07-2016 16:22
@SkipII wrote:Yes, did that, but how do I get it to show up on the tracker?
If you sync your tracker after you make the changes in your app setup, it will download those changes to the tracker.
Best Answer12-07-2016 16:34
12-07-2016 16:34
I did a search on the site nd it talks aobut how to troubleshoot a problem with synching but I cnanot fidn where it talks about how to sync normally and how you know the device is synced.
Best Answer12-07-2016 16:59
12-07-2016 16:59
There are two easy ways to manually sync from your phone Fitbit app dashboard: 1) Pull down on the main dashboard, and it will start the sync and display the status at the top of the screen; and 2) Select the tracker icon in upper right hand corner of the dashboard, and it will open the Account screen showing your Fitbit device. Click on that device, and it will start syncing.
From the Account screen described in #2 above, it will show the last time it was synced, like this:
Best Answer12-10-2016 09:44
12-10-2016 09:44
Hey my friend @SkipII! See this post of my to navigate on your Charge's 2 screen and find the way to track your walk activity.
Good steps and tips my friend @USAF-Larry. ![]()
Happy stepping!
Best Answer02-26-2019 09:37
02-26-2019 09:37
How do I set up choices to track, such as walking?
Best Answer02-26-2019 10:24
02-26-2019 10:24
@_mh please see @DerrickS post above, he links to the multisport FAQ, question 2 has your answer.
