01-01-2019
00:39
14:31
01-01-2019
00:39
14:31
So my charge 3 will vibrate every 20sec (a guess I haven't timed it) when I start a walk workout ... Unless I keep my phone screen on .... Then it doesn't do that... obviously my phone screen times out after a while and then the vibration starts again and I have to turn my phone screen back on .. which is extremely annoying when you were trying to walk... Fix to this?
01-01-2019 01:10
01-01-2019 01:10
Wow, thats a weird one! Try restarting it several times. If that doesnt fix it try a long restart. If that doesnat fix it contact Support (link in my signature) or returnnit to the store itnwas bought.
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
Helen | Western Australia
07-13-2020 23:29
07-13-2020 23:29
Is your mobile phone on low power mode? When I turned this off it stopped the vibrating.
