01-01-2020
01:12
15:40
01-01-2020
01:12
15:40
Hi,
I've just bought a charge 3 and input my weight (12 st 7lbs) and on the watch it is showing 12.5st 7lbs. This is obviously an error, is there a way to correct it?
Thanks
A warm welcome to the Community, @Antraw.
If you are having issues with this information, I recommend making sure you are saving your data by doing the following:
Let me know the outcome. 🙂
Best AnswerHi,
Thanks for the reply. I tried updating the information and the app is showing it correctly (as 12.5stone or 12 stone 7lbs) but my fitbit shows 12.5st 7lbs. I experimented and changed it to 13.5stone on the app - my fitbit showed 13.5 stone 7lbs. I also changed it to 11.5 stone on the app and it showed -0 stone 10.9lbs. I'm not sure what the error is. Any ideas?
Thanks, Anthony
