07-25-2019
08:45
14:11
07-25-2019
08:45
14:11
I am trying to make a picture of my Sleep stages to use for a slide show. Where does the 'share' button send the info to? It goes somewhere I suppose, but where so I can retrieve it? Or if there is a simpler way to get the image of my sleep stages saved on my PC that would be great.
Any ideas are welcome. and thanks!!!
07-25-2019 11:34
07-25-2019 11:34
The simplest way should be to take a screen cap with your phone. I think all phones have that capability but procedure varies somewhat by phone.
On my LG, can press the off button on back just slightly, not far enough to turn off;
or there's some other button combo, maybe volume up and some other button together.
If want to try share, it goes through several questions before committing to where it is going; eventually get to a place where can share with friends on fitbit or other option is: other places. I didn't check that far, but feel free to try without accidentally sending it somewhere you don't want; it gives you choices and you have to pick, or could just back up at end.
07-25-2019 12:40
07-25-2019 12:40
Best Answer07-25-2019 13:08
07-25-2019 13:08
On my app, where you have the option "Friends", at the bottom is a red "Post" button and just below that, in fainter print, "Share elsewhere".
I selected 'share elsewhere' and it shows me ~ 20 choices, all I have texted to, email, facebook, set as profile pic, ...
Best Answer07-25-2019 13:34
07-25-2019 13:34
Best Answer07-25-2019 13:41 - edited 07-25-2019 13:43
Way past that. On that screen, just tap 'Next' at top right, then 'Next' on next screen which is 'Compose' for message accompanying pic, then I get 'Friends' with Post and Share Elsewhere.
Just be bold and keep clicking 'Next'.
Hadn't seen your last post yet.
Best Answer07-25-2019 14:27
07-25-2019 14:27
