02-08-2020
03:27
15:03
02-08-2020
03:27
15:03
Woke up yesterday to white lines on my display, tried to restart and changed the clock and no difference. Bought last summer, never had an issue before.
02-08-2020 04:17
02-08-2020 04:17
@Prend It seems like you've done all the troubleshooting already, so you should use this link to contact customer support for further advise. Best of luck!
02-08-2020 04:17
02-08-2020 04:17
02-08-2020 04:58
02-08-2020 04:58
This charge three has been the worst Fitbit I have ever had the first one I had in November 2018 the screen went completely black so they sent me a new one at the beginning of August 2019 now I have white lines and my battery is running down very quickly like it sent before it’s barely been six months
02-08-2020 05:18
02-08-2020 05:18
02-08-2020 05:21
02-08-2020 05:21
02-12-2020 01:01
02-12-2020 01:01
Yes it's all sorted with customer service, I am still under Warranty, so I have a new one on the way.
05-21-2020 07:22
05-21-2020 07:22
I had close to the same issue. I changed the clock face and after I did white lines appeared On the clock. Read the thread and others. Changed the clock face back and then reset. Still has white lines. Called customer service and after a short trouble shooting session was told my watch is out of warranty so I will have to buy a new one. Lesson Learned for me was don't change your face or you run the risk of breaking your charge 3.
07-11-2020 20:30
07-11-2020 20:30
I had my Charge 3 replaced in December because it wouldn't turn on (just shy of the 1 year warranty thankfully) but now the replacement is having the white line issue. Does anyone know if it's under warranty?
01-02-2021 14:34
01-02-2021 14:34
I have white line running through the face of my Charge 3. I have re-set it several times. Nothing has helped.
01-02-2021 16:11
01-02-2021 16:11
It did have a one year warranty. If they had to send you a new watch, it should have a new one year warranty. At least that is the way mine was when they replaced it after eight months. I'm looking to upgrade but afraid the Charge 4 will be just as bad as far as the display. First one had lots of lines and white spots in different places. The second one (which did not make it a year before beginning to have problems) started having the same issues in late spring or early summer. Both had the worst displays when outside. If I was out exercising, I couldn't tell what I had accomplished as you can't see it on a sunny day. Screens messed up on both. Unfortunately due to family member's health, I was not able to stop and contact FitBit. Sleep info came and went. Usually okay but had went several days not recording and I keep my watch on 24/7 unless charging. I'm even afraid to go with the Sense instead of looking at Apple or Garmin because of the experience I've had with this one. I guess you get what you pay for.
