01-01-2021 03:50
01-01-2021 03:50
I cannot pair my charge 2.
I have tried restarting my phone. Resetting mg Bluetooth. Reinstalled the app. Resetting my charge 2. Removeed and reconnected a new device. Nothing works so far. It's very upsetting that my charge 2 just stuck on a wrong day and wrong time. 😞
01-01-2021 06:12
01-01-2021 06:12
Hi @MGG we really need a little more info.
Why was the Charge 2 removed from your account?
What phone do you have?
You say that you can't pair, that is correct. We need to setup the tracker through the Fitbit app.
When performing the setup
At what step does the failure occur?
Any error messages?
Best Answer01-01-2021 08:13
01-01-2021 08:13
Best Answer01-01-2021 08:39
01-01-2021 08:39
The question still remains unanswered. Are you doing the Add Device to your Fitbit account through the fitbit app?
Once the Charge 2 has been added to your Fitbit account. The Fitbit app will ask for permission to pair the charge 2.
Removing a non syncing device from the Fitbit app will never fix the issue, and I'm most cases simply dig a deeper hole to climb out of.
Best Answer01-01-2021 09:02
01-01-2021 09:02
This is an ongoing problem with Charge 2 trackers on Pixel phones. Fitbit is aware as there have been many threads on here since like July I think is when the initial problem started for a lot of people. The mods here will link you to some basic troubleshooting that won't work so what the community found out was that if you have another device like an iOS or Windows device, or maybe another Android device that isn't a Pixel then you can remove the tracker from your account and re-add it from that other device. Just go through the normal steps and when it finishes and syncs, turn Bluetooth off on that device and go back to the Fitbit app on the Pixel and try to sync.
I've found there are still some things that aren't acting correctly but if you just want it to pull your data then it does that. But the app on Pixel phones is in a weird state and it's gone 100% unaddressed for at least the last half of 2020. Here was the last thread that gained any traction but you'll still see no response from Fitbit.
Best Answer01-01-2021 09:04
01-01-2021 09:04
Best Answer01-01-2021 10:34
01-01-2021 10:34
