05-31-2019
12:20
15:47
05-31-2019
12:20
15:47
Why does it show I get more sleep when my sleep is set to sensitive.
06-01-2019 08:14
06-01-2019 08:14
Hi @Vibeke.
I don't know. The sensitive setting is for when sleep tracking is logging too much sleep. It usually will result in more awake time, not less.
I would try a restart of the tracker, and see if that helps.
https://help.fitbit.com/articles/en_US/Help_article/1186
Regardless, you should use the setting that produces the most accurate results for you.
Best Answer06-03-2019 11:03
06-03-2019 11:03
