04-12-2019 14:58 - edited 04-12-2019 14:59
I've ordered a Fitbit Inspire HR (Lilac, crossing my fingers on the battery issues) for my wife and I'm interested in getting a 3rd party band or two for her to go with it. In particular, thinking about a Milanese band, Champagne or Gold. Has anyone found any good ones?
Best Answer04-13-2019 08:02
04-13-2019 08:02
https://www.amazon.com/gp/product/B07NJCTQ33
I have the black one. It was a little tricky to put on as the pins have to be slid into the band and can fall out and lost. They give you 3 pins, however. It was also a little tricky getting the ends of the pins lined up properly, but once one, it's been pretty good. I keep it on during showers and no rust/corrosion (yet).
Install over a white towel, so that when the pin does slide out, you won't lose it.
04-12-2019 21:41
04-12-2019 21:41
I myself have not had a problem with 3rd party bands
But I do look at feedback from others on the sellers before I buy
Been some bad reviews and I run away 😀
Wendy | CA | Moto G6 Android
04-13-2019 08:02
04-13-2019 08:02
04-13-2019 17:30
04-13-2019 17:30
@brutus001 Funny, that’s the one I have in my cart, albeit, in Champagne
