02-05-2021 06:00
02-05-2021 06:00
Any progress on adding cross country skiing as an activity for the Inspire HR?
Best Answer02-05-2021 07:57
02-05-2021 07:57
Hi, @pmcd1032 , you cannot add cross country skiing as an activity to track directly from your Inspire HR, and, as far as I know, there are currently no plans to add it. You can easily track your cross country ski activity as a "workout" and then once it syncs to your app you can quickly edit (rename) the activity to cross country skiiing. The app will estimate your distance and pace as well as giving you other stats (calories, heartrate).
If you want a map using GPS data you will need to track it as a "hike" or "run". There will be no difference in your data - just the label will say hike or run rather than cross country ski. Unfortunately that is the current workaround.
I hope this helps.
02-05-2021 08:06
02-05-2021 08:06
Thanks so much, Julia
