12-01-2019 05:36
12-01-2019 05:36
Why my phone won't pick up Bluetooth to Fitbit
Best Answer12-01-2019 13:32
12-01-2019 13:32
I'm having the same problem. It connects and syncs randomly.
Best Answer12-02-2019 23:29
12-02-2019 23:29
I'm not sure what you mean @Holthaus and @BugsMom425?
Your phone can not connect to your trackers Bluetooth.
You need to use the Fitbit app to setup the tracker by doing an add device.
Best Answer12-03-2019 02:29
12-03-2019 02:29
My phones Bluetooth will NOT recognize the tracker. It was set up 100% and then I started having problems with syncing. Go into my Bluetooth paired devices and it's gone. I have NO problem with my Aria
Best Answer12-03-2019 08:13
12-03-2019 08:13
Who cares @BugsMom425 the phones Bluetooth doesn't have to see or have the tracker show as a trusted device for the app to sync the tracker. One of the steps in troubleshooting is to remove the tracker from the Bluetooth.
May I ask what phone you have?
Have you checked the Help Docs?
As for the Aria it syncs through your home router, not the phone.
Best Answer12-03-2019 10:28
12-03-2019 10:28
Best Answer12-03-2019 10:31
12-03-2019 10:31
That's because the tracker is not syncing. Without knowing anything about the phone prohibits me from helping out more.
