07-30-2019 02:13
07-30-2019 02:13
Please can anyone tell me if my Android Samsung Galaxy J2 Pro phone (which I own/use) will be compatible with a Inspire HR?
If not what type of tracking device (sleep/heart rate/steps should I be looking at that will be compatible with my phone?
I do not want to buy a new phone and like the narrow look of the Inspire HR.
Any help sincerely appreciated please.
Kind regards and appreciation
Regards
Megams
Best Answer07-30-2019 02:34
07-30-2019 02:34
Hi @Megams It is not on the Supported Devices List but in its self that doesnt mean it wont work. I do know there are difficulties with some of the Unsupported J series phones, but cant tell you if that one will work or not.
Helen | Western Australia
07-30-2019 02:52
07-30-2019 02:52
Hi Helen
Thank you so much for your prompt reply.
I did have a Fitbit Altra which would not sync with this phone when I bought it so sold the Fitbit recently.
I really want to find a suitable tracker/fitness support band of some sort and hope my phone is not going to be an issue. It seems such a waste of money as phone only 3 years old if that.
I noted the J2 was not mentioned on the list and don't know if to go ahead & buy the Inspire HR or not.
Kind regards once more
Megams
Best Answer07-30-2019 05:14
07-30-2019 05:14
@Megams If and Alta didnt work with you phone, I very much doubt an Inspire will. The Alta uses an older less complicated Operating System so I dont think the Inspire, which demands more of the connection to your phone, has much chance of working with it. Sorry
07-30-2019 11:24
07-30-2019 11:24
Hi NellyG - Sorry for not getting your original name correct . Thank you very much for your help, most appreciated.
Have u got any tips for which Fitbit or other such similar device I could choose that would be compatible with my phone? I'm only wanting to monitor steps & sleep - nothing too complicated at all. Our tech age is advancing sooooo fast......
Megams
Best Answer07-30-2019 22:41 - edited 07-30-2019 22:43
If the Alta didnt sync with the phone then there is unlikely to be any fitbit that will, I am sorry.
As far as my name - both are correct! So not a problem😊
Best Answer07-31-2019 00:54
07-31-2019 00:54
Really appreciated your help NellyG so thank you so much for your replies.
Have told the store concerned to cancel my order of the Inspire HR.
Scratching my head to see what I can do next??
Megams
