01-20-2020 13:54 - edited 01-20-2020 14:05
Hi. Hope someone can answer this. When I’m exercising in the gym my Fitbit automatically tracks my treadmill workout. However I know it doesn’t do so for the exercise bike. if I manually add my bike workout will that give me an inaccurate reading of my calorie burn, ie add it twice. I mean, isn’t the Fitbit tracking my calorie burn from my heart rate etc anyway?
Thanks!
Steve
Best Answer01-20-2020 13:59
01-20-2020 13:59
First issue: you have labeled this post as "Inspire" which does not measure heart rate. Do you have Inspire or Inspire HR?
Best Answer01-20-2020 14:04
01-20-2020 14:04
Oops. Meant to hit Inspire HR!
Best Answer01-20-2020 15:44
01-20-2020 15:44
1) The best way to do it is to use the Exercise App, manually starting and stopping it from wrist, eliminating any question of whether or not it will get detected, and using the actual recorded data.
See How do I track my workouts with my Fitbit device?
2) If you will not use the Exercise App, you have 2 choices:
a) Just leave the data as is, which gives correct daily stats but doesn't let you see the stats breakdown by workout.
b) Manually log it after the fact, which is intended for cases where you were not wearing the tracker. In this case, it overwrites everything that was recorded, and gives calories, active minutes, etc based on the parameters you select when logging it. So no, it does not credit the workout twice, but it also is probably not quite accurate.
Incidentally any manually logged steps will not count in challenges, only data actually recorded.
