05-29-2019 22:46
05-29-2019 22:46
My Inspire HR started vibrating randomly today and then died. I plugged it in to charge for several hours, to no avail. I tried restarting it several times, with no luck, but finally ended up with a screen that has the 001 code and QLZEIPT2 above it. The Inspire unit will now not shut off. Unit is 2.5 months old.
Cheers,
Marc
Best Answer05-30-2019 02:17
05-30-2019 02:17
Hi @Marc_AK_Fit That sounds rather strange! I have flagged a moderator to come and help you.
Helen | Western Australia
Best Answer05-30-2019 05:36
05-30-2019 05:36
Welcome to the Forums @Marc_AK_Fit. Thanks for bringing this up @NellyG.
Thanks for sharing the situation that you have experienced, the steps that you tried and the error code that you got @Marc_AK_Fit. Thanks for being around to help @NellyG.
@Marc_AK_Fit The first thing I'd like to ask you is to confirm if you have tried to restart your Inspire HR? If you have not, please do try to restart it and run the set up as if it was a replacement device.
Please keep me posted on how it goes or if you have any other questions on the matter.
Best Answer05-30-2019 11:15
05-30-2019 11:15
Hello Lanuza,
As per the original post, I tried to restart the unit multiple times and it did not work.
Cheers,
Marc
Best Answer05-30-2019 12:54
05-30-2019 12:54
Hello @Marc_AK_Fit.
You are correct, I apologize. Thanks for your prompt reply.
Our support team will be getting in touch with you about this situation via email. Please keep an eye on your email's inbox, spam and trash folders. They will be more than happy to help you figure out what is going on and find a solution.
Let me know if there is anything else I can help you with at this moment.
