10-06-2019 20:26
10-06-2019 20:26
My fitbit does not respond. It cannot scroll and when I long-press the button, it vibrates but the screen stays on the time. I have charged it but it still stays the same. The time is right though. My syncing device is a android.
Best Answer10-08-2019 11:05
10-08-2019 11:05
This happened to mine a few weeks ago. Try going into the app and changing the clock face. That should refresh the entire device and it should work again like normal after. You can go back to your old watch face afterwards.
10-06-2019 20:31
10-06-2019 20:31
Mine is doing the same, except the screen is off. It still vibrates when I get a notification, and still counting everything when I check the app. The screen is just blank.
10-06-2019 20:40
10-06-2019 20:40
Same thinf happened to me. Its still frozen and I am not happy.
10-08-2019 11:05
10-10-2019 01:22
10-10-2019 01:22
Thanks. Great tip. I had the same problem (Inspire froze) and this has resolved it.
Best Answer10-10-2019 03:41
10-10-2019 03:41
Thanks a ton! This helped 👍🙂
Best Answer03-26-2020 12:25
03-26-2020 12:25
I just did as you’d suggested, and it fixed the problem. Thanks 🌺
