Hi, I was wondering if anyone knows if it's possible to have a tile on the inspire for food? When I scroll down from the clock I can see a tile for water but not for food.
Best AnswerHi, @SunsetRunner , no, unfortunately a tile for Food intake is not available on the Inspire, and you cannot add this under settings.
Here's what the Inspire manual says:
Swipe up from the clock face on your tracker to see your daily stats, including:
-- Core stats: Steps taken today, calories burned, distance covered, and active minutes
-- Hourly steps: Steps taken this hour and the number of hours you met your hourly activity goal (tap to switch between these stats)
-- Exercise: Number of days you met your exercise goal this week
-- Cycle track: Information on the current stage of your menstrual cycle, if applicable ------- Sleep: Time spent asleep Water Water intake logged today
-- Weight: Current weight, progress toward your weight goal, or where your weight falls within a healthy range if your goal is to maintain your weight If you set a goal in the Fitbit app, a ring shows your progress toward that goal.
Unfortunately Food intake is not among these. If you would like to see this added, you may like to submit a feature request here. Be sure to do a search first to see if someone has already made the same, or a similar, feature request.
You can, of course, always view your logged food intake in your app, even though it is not available on your wrist.
I think there is, under the Account Settings.
one cruise ship at a time!
