Fitbit in clip not recognising sleep pattern
Hello
i prefer to wear my fit bit on clip but have tried different settings however not getting any sleep recognition on the unit. Pls advise what I can do to set fitbut on clip to pick up my sleep patterns.
thanks
3 REPLIES 3
Hello @PKuwait and a warm welcome.  I don't own an Inspire, but I did some searching for you.  I found this thread where the best answer says that the Quick Setting on the Inspire should be on the On Wrist setting to detect sleep.  To get to the Quick Setting, press and hold the button for about 2 seconds.  I don't know if the Inspire must be on your wrist.  Another user said that sleep was detected with the tracker on the torso.
Here is a link to the Inspire Manual , but it doesn't get specific about tracking sleep.
Can you be more specific about the things you have done to track your sleep?
Laurie | Maryland
Thanks so much.
Good response as a lot of users seem to be struggling with it
I will try using the wrist mode and also clipping the unit in my bangle as it certainly didn’t pick on my T shirt or pyjama 😂
Thanks
Poonam Sharma
So have tried wearing the clip in clip mode and wrist mode on T shirt and pyjamas. However nothing tracker. So tonight will try wrist mode and wearing on my wrist Attached to my bangle as I don’t want to fiddle changing the strap every night from the clip. Will report back 🙏🙏
