09-08-2019
03:54
10:27
YojanaFitbit
09-08-2019
03:54
10:27
YojanaFitbit
Hi anyone else having similar issues? Inspire HR still tracking but I can no longer use touch screen and flick through menu. Also reminders to move and vibrate when goal reached no longer work. Already tried restarting and re-installing. Any help appreciated tks!
Best Answer09-08-2019 07:27
09-08-2019 07:27
Same thing is happening to me
09-08-2019 10:03
09-08-2019 10:03
I'm having the same problem, just started today
09-08-2019 14:49
09-08-2019 20:18
09-08-2019 20:18
Glad I'm not the only one. Got my fitbit in March 2019 and I'm having the same issue. If a moderator is reading this, I have reset it about 50 times today and that has not helped so for the love of all things, don't tell me to "follow these steps to reset it". Reseting it has done nothing.
09-08-2019 20:24
09-08-2019 20:24
I reset mine and it is working ok. For now anyway.
09-08-2019 20:59
09-08-2019 20:59
Mine is not letting me scroll through the menue on the screen either. I haven't reset it. I don't know how.
09-08-2019 21:04
09-08-2019 21:04
Hook it up to the charger, with power. Hold the button for 5 seconds. A smiley face should show up. Keep the button pushed. The clock should now show. Release the button. You should be able to scroll. Hope this works.
09-08-2019 21:38
09-08-2019 21:38
Also having this issue. Started about two hours ago. 😞 I've reset it, changed the clock face, charged it, kept it plugged in while restarting it, etc. Nothing works. Won't let me scroll. I can't get to the setting option to do a factory reset either.
09-09-2019 01:23
09-09-2019 01:23
Yup. I have tried everything and still not working. Now heart rate tracker also gone (green light at back of tracker off ). Has come to the conclusion at less than a year old this Inspire Fitbit is probably unsalvagable.
Best Answer09-09-2019 04:08
09-09-2019 04:08
09-09-2019 06:53
09-09-2019 06:53
thank you, that worked for me 🙂
09-09-2019 10:09
09-09-2019 10:09
I have had this problem today. I have restarted it so fingers crossed.
09-09-2019 16:42
09-09-2019 16:42
I’ve had the same problem since day 1. Sometimes flicking through the screen works, sometimes it doesn’t. I’ve reset it multiple times which obviously has not fixed the problem. Very frustrating!
Pam
09-09-2019 18:51
09-09-2019 18:51
09-10-2019 05:34
09-10-2019 05:34
Thanks for the advice. This did work!
09-13-2019 10:24 - edited 09-13-2019 10:27
Hi everybody thanks for letting me know all the details that you've shared on your posts. Welcome to our new members. Sorry for the delayed response.
@Fadeonblue @Taveria and @pjynx I really appreciate the time you've taken in order to troubleshoot this with us. We've requested to our support team to create a case on your behalf. They will be contacting you shortly via email.
@Kelliewar Welcome to our Fitbit Community Forums. Please check if restarting your Fitbit will help to solve the issues that you're reporting with your Inspire HR. I'll be around.
Thanks for suggesting the restart @Wally69. I'm glad to hear that this is working for you @joysimmons @hollysmile and @beaglebailey22.
@Nokiagirl Thanks for restarting your Fitbit Inspire HR. Hopefully you won't have more issues with the display, since other users are reporting really good results after the restart. But in case that you need further assistance I'll be happy to keep assisting you.
Keep me posted with the outcome!
Best Answer09-13-2019 12:27
09-13-2019 12:27
Since restarting my Fitbit it has been ok. Fingers crossed it stays that way.
Best Answer09-13-2019 12:51
09-13-2019 12:51
it started for me this morning. I changed the clock face in the app and that fixed the issue.
I have the kitty clock face. 😀
Best Answer09-13-2019 21:43
09-13-2019 21:43
Thanks that worked
