02-05-2023
23:40
12:31
02-05-2023
23:40
12:31
I was on Livestrong the website "MyPlate" before I got my Fitbit and it was so easy to create a custom recipe in the meal plan with each ingredients and then pick serving size and calories per serving. Does anyone know how to do this on the Fitbit app?
I've been a member for years, every time I try to do try to add a custom food there is very little ability to enter any of the food/ ingredients. Do I need to go to the Fitbit dashboard to create a meal such as lasagna and then the portion size would be a serving size of a meal that I fixed for the whole family. This shouldn't be this hard it should be so easy to add the ingredients and the quantities and it would fill out each fileds and every one of the ingredients nutritional fields and at the end you should be able to pick a serving. And a calorie size Please help please.
Best AnswerHi, @slmorris05! I use myfitnesspal for food tracking, since it syncs food nicely with Fitbit. If you're looking for Fitbit to add better functionality, I'd suggest heading over to the Feature Request forum. There might be a request already existing that you can add your vote to or you can create a new request.
MakMak | Community Council
