How do I change the time on Inspire?
ANSWERED
Hi how do I change the time. It is showing 7.28 instead of 19.38. Thanks
1 BEST ANSWER
Accepted Solutions
If you'd prefer it to be a 24 hour clock then you can choose that in your profile settings at https://www.fitbit.com/settings/profile
Once changed and saved, you'll need to sync again to update your fitbit.
5 REPLIES 5
Is it off by 12 hours, or is it that you want 24 hour clock?
Hi I would prefer 24 hour clock but have got used to it now. Thank you for responding to my query
Thank you Steve for your help. I've now changed it to 24 hour clock
I have tried the above and it still shows 0806 instead of pm? Any ideas?
