04-20-2021
06:38
10:01
AndreaFitbit
04-20-2021
06:38
10:01
AndreaFitbit
The time is like 6 hours different than the actual time how do I reset it?
10:08
12:04
04-21-2021
10:08
12:04
Welcome to the Fitbit Community, @Blondie62. Thanks for sharing your inquiry regarding your Inspire HR time.
As @SteveH mentioned, you can't manually set the time on your Inspire HR. Sync your Fitbit device to see the correct time. For more information, see How do Fitbit devices sync their data?
Thanks for your help @SteveH.
You can't manually set the time, but it should reset itself whenever it syncs to your phone based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
04-21-2021
10:08
12:04
04-21-2021
10:08
12:04
04-22-2021
13:42
08:16
AndreaFitbit
04-22-2021
13:42
08:16
AndreaFitbit
My dashboard doesn't have syncing on it, my Fitbit time is 5 hours around and I have set my GMT to my time zone. What do I do?
Thanks for getting back to us @Blondie62. I'm sorry to hear your dashboard doesn't have syncing on it and that the time is 5 hours different to your time zone.
Where are you looking for the syncing option? Please follow the instructions of: Why won't my Fitbit device sync?
Keep on visiting the forums.
