04-23-2019
20:54
08:46
AlejandraFitbit
04-23-2019
20:54
08:46
AlejandraFitbit
So my inspire says I need to delete an alarm to set a new one I have too many But when I hit the set alarm icon it just keeps telling me the same thing I don’t see my alarms or the ability to delete it
I am pretty tech dumb and would really appreciate any help.
Hi @46263jab In your app on your phone go to Inspire (select the tracker Icon in the top right corner) and scroll down to Silent Alarms and select. That will show you the alarms you have. Select one you want to delete and a new page comes up with the alarm details. One of the options at the top is Delete.
Helen | Western Australia
08:47
09:53
04-25-2019
08:47
09:53
A warm welcome to the Community @46263jab and @NellyG thanks for the input.
I was able to see here that our friend @NellyG provided some instructions in order to delete your alarms. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
Best Answermine doesn't have delete option. lap top computer
08:05
09:53
04-08-2021
08:05
09:53
It’s good to see you in the community, @cindyreams.
Thanks for the details shared in your post. I appreciate your efforts and recommend following the instructions in How do I delete or turn off alarms on my Fitbit device?
Hope this helps!
