11-10-2019
06:12
08:08
AlejandraFitbit
11-10-2019
06:12
08:08
AlejandraFitbit
Is there a way to remove alarms from apps?
11-10-2019 06:27
11-10-2019 06:27
Hello @larrybarr, welcome to the Fitbit community! Tap on your profile picture, press inspire/inspire hr, tap on alarms, and then click on the alarm you'd like to delete. You should see delete in the top right corner.
08:15
06:31
11-11-2019
08:15
06:31
Welcome to the Community, @larrybarr and @Courtneythegirl, thanks for the input.
I was able to see here that our friend @Courtneythegirl provided some instructions in order to turn off or delete your alarms. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 🙂
10-08-2021 10:06
10-08-2021 10:06
Go to the alarm app on you device , get to the screen the shows the time and the little red alarm clock with the slash through it and press the actual number or time setting , the screen with the Smart Wake and off - on section should appear . Swipe up from there and the days of the week will appear and at the bottom will be the remove alarm button. Press this to erase that specific alarm , you will need to do so for the specific alarms you are wanting to get rid of !!!!
