10-01-2022
00:21
21:04
10-01-2022
00:21
21:04
Is is possible to export all the data? Can i download csv. files of all my data from the last 5 years of usage?
How accurate is the sleep tracking?
Any big pain points with this device? Does it break often?
Would you recommend buying another strap than the default one?
10-03-2022 13:22
10-03-2022 13:22
I would not recommend buying from fitbit at all to be honest. I bought my second one last spring. It came with some issues, which I was willing to troubleshoot. I have contacted support many many times in the past months and have had absolutely no help regarding this issue. It is a waste of time and money in my opinion, and I wish I would have gone with another brand. I hope this helps you before you get trapped. Sorry for being a negative nancy, but I would have wanted to know before I bought.
