I need to reset my son's inspire and clear all the old data. When I read the manual and watch videos online they all show a "Clear All Data" option under settings, but my son's options under settings are very different. There is a reset but not a clear data option. What do I do?
@SarahBlackwell , A warm welcome to the Community! Thank you for your message.
Just to confirm the Fitbit model your son is using.
Does it have a color display or is it monochrome?
Does the charging cable have a button on it?
If the display is a colored one, then your son is using an Inspire 3.
If so on the settings, you should see a sub menu Device Info > Clear User Data.
