04-12-2024
02:55
10:24
ManuFitbit
04-12-2024
02:55
10:24
ManuFitbit
Since a month the Fitbit does not receive the correct gps of my iPhone 12 when I am walking with training switched on in the Fitbit. At the end the gps does not receive the correct walk I did! I walk around a lake but according according to the Fitbit am walking in the water. I tracked it als with Strava which uses also the gps of my iPhone and it received the correct km and the correct round I walked. It seems a software bug in the Fitbit! I checked if Fitbit is connected correctly for the iPhone and it is. Does someone else have this issue?
Moderator edit: clarified subject.
04-12-2024 10:22
04-12-2024 10:22
Welcome to the forums @SunsetRunner.
Thank you for taking the time to share all these details regarding the Inspire 2 and for trying to fix it on your own. Sorry to know the inconvenience.
Please, follow the steps suggested in this article: How do I get my Fitbit device to connect to GPS? Take a look in the tips listed in (phone) connected GPS.
Also, check that no battery saving app/feature on your phone is affecting your Fitbit app.
11:16
10:31
ManuFitbit
04-12-2024
11:16
10:31
ManuFitbit
Thanks, all settings are set correctly as suggested in the link.
when walking iPhone en Fitbit at 50 cm from each other.
But still does not work!
Best Answer04-16-2024 09:29
04-16-2024 09:29
I have been having the same issue for about 3 months. It seemed to coincide with an update. It also no longer allows me to track any type of exercise except walking. Even if I select run or circuit it defaults back to walk.
Best Answer04-20-2024 05:00
04-20-2024 05:00
I have been having this problem and all I get from Fitbit is that 'they know'
