08-22-2022
07:11
21:04
08-22-2022
07:11
21:04
My Inspire 2 has started blinking. Anytime the light turns on, it will then turn off and back on again--sometimes just once, sometimes multiple times. It also no longer goes into sleep mode at night, so it blinks all night. This wakes me up, and it runs down the battery. I am about to give up on wearing it at night and go back to just using the pedometer. It is a rather expensive pedometer! The device is only about 6 months old. Can somebody help me?
08-22-2022 06:12
08-22-2022 06:12
08-22-2022 07:17
08-22-2022 07:17
Hello @sgbednar
I would suggest trying to restart your Inspire 2 to see if that helps resolve the issue. Plug the Inspire 2 into its charger then Just press down and hold the button on your Fitbit until you see a smiley face icon then release the button. You should feel your Fitbit vibrate telling you the restart is done.
If the problem persist try changing the clock face on your Inspire 2 by going through the Fitbit App. Here’s how: https://help.fitbit.com/articles/en_US/Help_article/2311.htm
😉 I’m hopeful this will help. Please let me know how it goes
08-22-2022 07:45
08-22-2022 07:45
Thanks--I will give this a try!
08-22-2022 08:10
08-22-2022 08:10
🤞😉 I hope it works out. Let me know
08-22-2022 08:12
08-22-2022 11:44
08-22-2022 11:44
Where can I find this please as mine doing the same and now not registering steps
08-22-2022 11:47 - edited 08-22-2022 11:47
08-22-2022 14:26
08-22-2022 14:26
Unfortunately, after restarting, recharging, and installing a new clock face, it still blinks. I won't know about whether or not it sleeps until tonight, but the ongoing blinking is not encouraging.
08-23-2022 04:24
08-23-2022 04:29
08-23-2022 04:29
Hello again @sgbednar
Do you set a schedule for your Inspire 2 to go into sleep mode? Here’s a great YouTube Video with step by step instructions on how to properly navigate through the sleep mode settings: https://m.youtube.com/watch?v=X075FemCVT0
You can also try turning off the Screen Wake feature at night if you don’t want to have the sleep mode. The screen wake feature should automatically turn off while Sleep mode is on but maybe it’s malfunctioning.
Screen Wake prevents the screen from lighting up when you turn your wrist or move around in bed while sleeping. To turn if off just hold in the left button a few seconds; look for 'Screen Wake'. You might have to scroll down to see it. Tap 'Screen Wake' to prevent screen lighting with wrist turn. In the morning you will have to remember to toggle it back on if you like the screen to wake with a wrist turn.
😃 Give that a try and see if that improves the blinking issue.
08-23-2022
05:39
12:30
EstuardoFitbit
08-23-2022
05:39
12:30
EstuardoFitbit
Well, it did not work! It still blinks, does not sleep, and this morning the screen is frozen. I can't do anything at all--not even scroll!
It is not. The screen display turns on, turns off, turns on, turns off, usually two or three times. Sleep mode does not work. It is running down my battery. This morning the screen is frozen.
It has a schedule. It just doesn't work. The blinking happens during the day as well, and it is running down my battery. Now the screen seems to be locked, so I can't do anything at all...not even scroll!
08-23-2022 06:07
08-23-2022 06:07
‘It’s possible you accidentally put your Inspire 2 on water lock. To unlock your Inspire 2 firmly tap your screen twice.
Since restarting your Inspire 2 failed to address the “blinking” issue I’d try restarting one more time. If the issue your experiencing continues I’d contact Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US
Let me know if this helps
08-23-2022 12:41
08-23-2022 12:41
@sgbednar Fitbit discourages cross posting. You have an identical post in the Inspire 2 forum. I'm merging this thread with the device forum thread. This is a better fit for this issue. This is a device issue, not an Android app issue.
No harm, no foul.
Laurie | Maryland
08-23-2022 15:28
08-23-2022 15:28
@sgbednar It’s obvious that @SunsetRunner has no personal experience with the Inspire 2. As an Inspire 2 user, you can’t do it by accident and not know it. The list of try this, try that recommendations has only one useful recommendation. Contact Support.
08-23-2022 16:13
08-23-2022 16:13
😉 @NanaRuns it’s possible for some. I’ve personally come across individuals here on the community accidentally placing there Fitbit in water lock mode and need assistance getting out of it. It happens…especially when the screen is not functioning properly.
08-24-2022 09:41
08-24-2022 09:41
My device is not on water lock. After downloading the new firmware, the screen is no longer locked up. It does, however, still blink. This morning when I woke up and looked at my device, it blinked 17 times before turning the light back off! I have tried customer service about a half dozen times, but it has not been available. I guess I will just keep trying.
08-24-2022 09:45
08-24-2022 09:45
No. It did not work. Downloading the new firmware update unlocked the screen, but now I am left with the original problem--incessant blinking! Customer service has been unavailable. I guess I will just keep trying to get them.
08-26-2022 07:17
08-26-2022 07:17
Thanks to all who tried to find me a solution. I sent my device back to the factory yesterday, as it is clearly defective.
08-26-2022 07:46 - edited 08-26-2022 10:19
Went you say you “sent my device back to the factory” do you mean you factory reset your Inspire 2 or you sent it back to Fitbit?
If you Factory reset your Inspire 2 would you like to try and set it up as a new device again to see if the original issues resolve after setting it back up?
Setting up your Inspire 2 as a new device will not make you lose any data as your data is held on the Fitbit Servers. You will however lose all data that occurred after your last successful sync.
To set your Inspire 2 up again as a new device please follow these steps closely:
🤞 Hopefully that will get you up and running again. Let me know how it goes.
