01-10-2021
09:43
13:08
SilviaFitbit
01-10-2021
09:43
13:08
SilviaFitbit
Sleep data was showing no problem till around jan 2 then it just stopped. Nothing resets it. Reading on here seems im not the only one. So did something happen ? Maybe an update thats caused it?if it.cant be fixed, i ll be buying another brand.
01-10-2021 10:29
01-10-2021 10:29
I loved this feature and mine disappeared a few nights ago. I’m very frustrated with this Fitbit.
01-10-2021 12:30
01-10-2021 12:30
Bought mine on the 6th and it has only recorded one night. I do not know what is wrong!
01-10-2021 13:18
01-10-2021 13:18
Exactly! I got mine about the same time. Only one night and gone. I don’t have the sleep tile anymore.
01-10-2021 14:23
01-10-2021 14:23
This is my first fitbit ans since I got it on Jan 8th, its only doing the active states. No sleep score or sleep stages. Its set to wrist and I have the app on in the background. What am I doing wrong?
01-10-2021
14:51
16:45
EstuardoFitbit
01-10-2021
14:51
16:45
EstuardoFitbit
Hope we find a solution soon.
My sleep tracker worked perfect last night! I hope yours did too.
Mine sleep score worked perfect last night. Yesterday I went through all the settings and looked through the app, there was a “sync” button on the app. Which I pressed, not sure if that’s what helped. Good luck, owners manual is 66 pages.
Mine worked last night, maybe Fitbit fixed their problem.
Moderator Edit: Merge replies
Best Answer01-11-2021 05:44
01-11-2021 05:44
My sleep worked perfectly last night (2 previous nights were not). Here are the 3 things I did:
1. Reset Fitbit- place on charger and press down on both sides till a smile face appears on the screen, it will automatically restart.
2. I wore the strap snug to wrist like I would while exercising
3. I turned my Bluetooth on my phone off at night and just turned it back on in the morning and synced with Fitbit
I did not tell the app I was going to sleep, it will automatically know after 1hr of not moving
Result: instant sleep score and all stages. It recorded how long I was asleep perfectly.
Hope this helps!
01-12-2021 07:30
01-12-2021 07:30
Hi, i ll try all that tonight. Using my old alta hr at the moment. It did sleep no problem at all.
Best Answer01-12-2021 13:15
01-12-2021 13:15
Hi everyone,
Thank you for the details mentioned and the troubleshooting tried prior to posting.
If your Inspire 2 isn't tracking sleep please confirm that On Wrist and Heart Rate are turned on in the Settings app, to access it press and hold both buttons.
If the previous settings have been checked but sleep isn't tracked. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
Let me know how it goes.
Best Answer01-14-2022 06:49
01-14-2022 06:49
not too happy, new fit bit Inspire 2. I have had no tracking on sleep , steps /hour x 4 days now. I have tried everything suggested . Manual is too long and complicated. I remember when setting up I used "on wrist" but now I can't find that to confirm. Settings app??? Do you mean settings when in sleep screen cause that doesn't work.
01-09-2023 07:13
01-09-2023 07:13
At what battery percentage is the Inspire 2 considered "critically low". I've checked my app, the user manual and searched online but I'm not finding that information. My Inspire 2 stops recording my sleep somewhere between 30 and 20 percent of battery. I am not getting a "battery low" warning before it stops working properly.
Best Answer01-12-2023 01:30
01-12-2023 01:30
I have had my Inspire 2 only for a couple of days, but both nights it stopped tracking sleep around 3.30AM while I was definately still sleeping (untile about 6.30 - 7). It tracked my sleep perfectly before this time and has a very accurate recording of when I went to bed. All settings are ok (sleep mode, on wrist, normal sensitivity, etc.). I have no clue why the device thinks I stop sleeping at 3.30 AM. For both nights I have manually changed my waking up time as I experienced this, but it feels a bit silly to do this since the device is in part designed precisely to track sleep and I think I'm messing up the data.
Best Answer04-14-2023 14:40
04-14-2023 14:40
I'm having the same problem but my Inspire 2 has stopped recording a full night when the battery is less than 60%. Ugh!
