10-23-2022
08:40
21:01
10-23-2022
08:40
21:01
Doesn't reguster daily steps seems to accumulate then disappears next Day charging ok wrong time showing up and not syncing properly
Hi, @MarieTherese , your Fitbit will show the correct time and update your steps if you get it syncing. The first step is usually to give your Fitbit a restart. Instructions are here . Immediately after the restart please try to force a sync. Sometimes you need to repeat the restart a couple of times before it syncs.
If the restart does not work after a few tries then please work through the steps described in this help article .
I hope this helps. Welcome to the forums!
