Hi, I have just received a Fitbit inspire HR for Xmas, I am unable to wear the band on my wrist at work, I have been looking at extender so I can wear on my wrist but have had mixed reviews. Has anyone purchased an extender for their Inspire HR which has fit properly? If so can you please ping me in the right direction of purchasing one. Many thanks
Best AnswerI don't understand. You can't wear it on your wrist, so want an extender so you can wear it on your wrist. Do you perhaps mean so you can wear it on your ankle?
If so, I would at least make sure to wear a sock over it to prevent it from falling off and getting lost.
Best AnswerSorry, yes was supposed to say ankle. All the band extenders I have looked at aren’t necessarily compatible with the Inspire HR and don’t want to get the wrong one.
I will wear socks at work over the top of the band to protect it.
