I just got off the phone with customer service about my new fitbit inspire HR. It is not syncing, it it not allowing me to press the watch heart screen for any detail, it is not keeping a watch feature like steps on for more than seconds, and the reason I thought this was going to be a better fitbit for me was the 24/7 heart monitor and the sleep monitor.
I am told that my Samsung Galaxy J7 phone is not fully "compatible" with this fitbit. There should be a way of noting this for customers--that some phones are not compatible with various fitbits.
This is the second fitbit I have had, the first one broke not long after the warranty was out and I have delayed getting another one but thought maybe the problems from the first one had been worked out.
VERY disappointed and as a friend said, it is an expensive step tracker. I wanted to be able to use these other features. Gave it a second try but am still not seeing the value and that there are so many variables to jump over if you are not an apple client. Terrible value for the money and this is the last try for a fitbit for me.
Best AnswerFitbits do work with most Android phones running at least Android 7.0.
However, most have not been fully tested to verify fully compatible. I have a phone that is not certified compatible but it works fine.
As for pressing the watch heart screen for more detail, it is not supposed to do that. That is for on the phone app, where you tap the heart rate tile for more detail. That is true for most of the phone app tiles.
Length of display on - yes it is short for all users - nothing to do with your phone.
I have no idea what variables you think you have to jump over, or what would be easier for an Apple client.
Syncing - that is sometimes an issue with all phones. Sometimes have to try a few times, or if have all-day sync turned on, can just it sync itself. What helps me sometimes is to turn phone's bluetooth off and back on.
