06-27-2020 13:26
06-27-2020 13:26
The touchscreen on my Inspire HR no longer works. I cannot swipe up or down from the clock face and I have tried to reset it over 5 times.
Best Answer06-27-2020 14:28
06-27-2020 14:28
Same... It has also gone completely dead in the past where reset didn't fix... An update always comes out a day or so later and it works after that... I'm really getting tired of these issues...
06-27-2020 16:00
06-27-2020 16:00
same just started a few hours ago, can't swipe and won't charge....
06-27-2020 17:22
06-27-2020 17:22
My Inspire HR touch display has not been visible in several hours too. It will charge though. Just started trying to investigate what to do. I figured it was just me.
06-27-2020 18:55
06-27-2020 18:55
Regarding Inspire HR. The screen on my fit bit is now not responding. No swiping.
I see I am not the only person with this issue. !!!!
Inspire HR still does not show the heart rate, nor BPM. The green light still does not work.
I worked with Support team member: Sebastian.GV and the Fitbit Team, 6/17 to get the fit bit to turn on and charge. Here I am again back on the board with same issue and MORE.
Restarting does not correct or fix this issue either.
My 4 month old insured fit bit still has a happy face when it restarts. I DO NOT!
It's like it's saying SUCKER!!
I am requesting replacement or money back. ASAP
06-28-2020 01:25
06-28-2020 01:25
Hi All,
I just got in contact with Customer Support about the issue. They will replace your fitbit if you get in contact with them and you are still under warranty. I bought mine about 1 year and 1 month ago, so I'm assuming the warranty is longer than a year.
Best Answer07-12-2020 23:44
07-12-2020 23:44
Same - my Inspire HR touchscreen also is having the same unable to swipe issue. The suggested 5 second reset while attached to USB magnetic power connector does not reset (no "smile"). I get a haptic "buzz" and the screen blanks but that's all.
The Inspire HR does appear to be tracking and can sync to phone app - showing "fully charged" but no local controls. Device side button press only brings up the time. No damage to band or moisture.
07-12-2020 23:46
07-12-2020 23:46
This has happened a couple of times and I was able to reset the device and it worked but now it will not even reset 😞
Best Answer07-12-2020 23:56
07-12-2020 23:56
I was able to get it working again by changing the clock face from the phone app - then changing it back to the original face - voila - able to swipe again!
07-13-2020 08:08
07-13-2020 08:08
This worked for me too! Thank you for this Wasted-spacer!! Just hoping this doesn't become the norm going forward.
Best Answer07-13-2020 08:16
07-13-2020 08:16
How? This is very frustrating.
07-13-2020 08:24
07-13-2020 08:24
Open the Fitbit app. Click on your picture (your account drop down) and select the device you are using. There you should see the clock faces option.
Best Answer07-14-2020 12:04
07-14-2020 12:04
So contacted support... They replaced... But right out of the box same issue... Screen worked for about 2 hours over last 3-4 days... Sent response to support that it is not working 2 days ago... No response!
07-14-2020 12:25
07-14-2020 12:25
Same. Started a couple days ago
Best Answer07-14-2020 16:00
07-14-2020 16:00
Any luck getting it to display again? Mine seems to be tracking my steps, etc. but no screen display.
Best Answer07-14-2020 17:13
07-14-2020 17:13
Time for a recall! These devices aren't cheap and I never get more than two years out of it. My Inspire HR is only a few months old and the screen won't display
