Hi there,
I upgraded from my Charge 2 HR to and inspire HR and I was wondering if there's a way to switch the date format on the clock faces of the inspire HR from MM/DD to DD/MM as I'm from Australia and the MM/DD is very confusing and at least with the Charge I was the date was my normal format...
And will there be any chance that we would be able to get a clockface with seconds as I need it for healthcare environment.
Thank you 🙂
Best AnswerYour best bet is to look at the different clock faces available. I just took a quick look and I think there are some that spell out the date, such as Dec 4, probably still not exactly what you are looking for. Maybe just try a few of the clocks.
There is no standard Fitbit way for switching date format, such as there is for switching between 12 and 24 hour time.
If you cannot find a clock face that suits, you can suggest that on the
Likewise for second hand; look at other clock faces, then maybe suggest on that board.
