Inspire HR does not record sleep properly
ANSWERED
On some nights my fitbit will show that I have not been asleep for a span of one to two hours.  I myself know that I was asleep but the fitbit doesn't.  I have used a total of three different Fitbits and all 3 have shown the same results.
1 BEST ANSWER
Accepted Solutions
Mine will show me awake at odd times, say from 3 am to 5 am. Sometimes it will show me going to sleep 2 or 3 hours after I actually went to sleep.
8 REPLIES 8
I found the same with mine, any answers?
I have the plain vanilla Inspire, and I'm having the same problem. I'm about to junk it  and go back to my old One. Or just quit the whole tracker thing.
@Scuzzy
Do you mean the reported "Awake" time on sleep stages ?
Thanks for your email, so this is normal for fitbits? Does it have
something to do with restless sleeping. I read somewhere there is a setting
for the sleep setting from sensitive to normal but i could not find.
Debbie
No what i am saying is that my Fitbit Isn't record my whole night sleep.  Last night it shows that I fell asleep at 10:56 and slept till @2:54 and then there is no record of my sleep until 4:44 to 7:26  There is a 2 hour gaap that is not recorded.  This has happened on a total of 3 different Fitbits.  What I am thinking is that my heart rate might be dropping low than what there parameters are set .
I'm having the same issue with my Inspire HR. I only started using it two weeks ago. There will be gaps of between 1 and 2 hours usually where it shows nothing. This has happened several times. Also having trouble getting it to sync with my phone on any kind of consistent basis. Guess that's a matter for another thread.
Mines doing the same thing ,did you ever figure out a solution?
