07-13-2019 12:09
07-13-2019 12:09
My battery completely died while I was away from and without my charger. When I try to restart my Fitbit, it will do nothing. I don't know if it charged or not. It makes buzz noises, and every so often when holding the button, a smiley face shows up, but it doesn't stay on. What is going on with my Fitbit?
Thanks so much! Any advice is greatly appreciated!!
KSerfess
Best Answer07-13-2019 19:37
07-13-2019 19:37
Hi @kserfess Try restarting your Inspire several times. If that doesnt get it going again then please come back here.
Helen | Western Australia
07-13-2019 19:37
07-13-2019 19:37
07-14-2019 12:12
07-14-2019 12:12
Best Answer07-14-2019 16:46
07-14-2019 16:46
Great you are getting a new one
Best Answer07-21-2019 08:10
07-21-2019 08:10
Yes, I did receive my new Fitbit. I just can't figure out how to reset, or how to switch the band. Life shouldn't be soo complicated!! Any suggestions NellyG?
Best Answer07-21-2019 08:35
07-21-2019 08:35
I can help with the reset, @kserfess. Plug it into the computer as if you were going to charge it. Next, you should see a button on the side of the device. Hold this down for about 10 seconds (I think), and when you see the smiley face appear, the restart was successful.
one cruise ship at a time!07-21-2019 12:09
07-21-2019 12:09
