Hi @Gauchat Check that the Quick View is turned on in your Quick Start Menu (long press on the button from the clock face). If it is On then try restarting the Inspire several tmes. If you continue to have problems please come back here.
Helen | Western Australia
Best AnswerIf it works sometimes it might be how you are flicking your wrist. I have got a lot better at it! I find the best way is to hold the watch horizontal and then turn to vertical in a definite move rather than a flick. Just make sure you move from the watch facing upwards to facing to your face - a full 90 degree motion rather than a flick. Let me know if that helps!
Best AnswerOk thanks for that added information. If you are familiar with the Charge 2 then you should be adept as the wrist flick. I will flag a moderator to come and help you.
Best AnswerA moderator never got back to me as promised. However, the problem resolved itself for the time being.
Best AnswerOh, I am sorry the mod never came back to you. I might have made an error when flagging so might be my fault. Let me know if youd like me to flag again.
