I’m looking for a tracker close to the now discontinued Alta. The closest would be the Inspire but I don’t like it’s ugly curved screen. I have a 5.5inch wrist what tracker would you recommend? Would the Versa or the charge look ok?
Thanks
Hi @syrupie you do have a small wrist. The Inspire is actually the replacement to the Alta series, but the Ace 2 is close. It has a smaller band, being a tad smaller than the regular version of the retired Alta. Do you like the looks of that style?
Best AnswerThank you that’s helpful the only reason I’ve been put off is that the Ace is for kids but nobody needs to know!
Best AnswerRead my other post? The Ace 2 can use the same band as the Inspire, so you've a lot of choices!
Best AnswerAND....I promise not to tell anyone it's an Ace2.
Best AnswerYou really don't like the Inspire? Why not go to a retailer that sells them and look at their demo models on display. Might be worth a look.
