07-06-2019 07:20
07-06-2019 07:20
I did the Fitbit upgrade and now can not figure out how to get my bpm heart rate to work
07-06-2019 21:02
07-06-2019 21:02
Hi @Magpie61 On the Inspire get the clock screen up and then scroll downwards and exercise will come up. Keep scrolling downwards until you get to Settings and select that and the scroll down to Heart Rate and check that is turned on. If it isnt, set to ON and all should be good. If it is already on, turn it to OFF then restart your Inspire HR several times and then go back and turn Heart Rate to ON and hopefully it will then be working. If it still doesnt work check thatbthe green light on the back of the tracker is flickering rapidly and come back here.
Helen | Western Australia
07-07-2019 09:30
