03-19-2019 23:53
03-19-2019 23:53
I noticed when I push my side button, I can see the screen light coming from the side of my fitbit. It looks like it’s coming from a crack between the acreen and then rest of the tracker. It only happens on the side with the button, the other side doesn’t have light coming from it. I’ve only had it for 2 days and I wasn’t sure if it was normal or not.
Thanks.
Best Answer03-20-2019 02:26
03-20-2019 02:26
Hi @PrincessSpyro, good to see you around.
I have just checked my Inspire and can't see any light coming from the side/button area. Would it be possible to post a picture of the issue?
Instructions on how to add images to your posts can be found here.
Thanks.
Best Answer03-20-2019 11:12
03-20-2019 11:12
Hi, I followed the instructions to post a photo on multiple devices, but it isn't working on any of them. It's giving me a screen that is asking for source, image description, dimension, and x. It's happening right above the button where the screen meets the base.
Thanks.
