01-03-2022
14:06
23:01
01-03-2022
14:06
23:01
My Fitbit is charged and based on the online dashboard, it's working fine.
However, I can't get it to show any readings -- the screen is blank.
The only way I know of to show the screen is to squeeze the sides, but that isn't working.
Any advice?
I don't have a manual for my Fitbit, so don't know what I should do next.
Thanks!
01-03-2022
16:30
08:54
AndreaFitbit
01-03-2022
16:30
08:54
AndreaFitbit
I have the same problem. Tried chat for help and got a programmed conversation. Not helpful
Moderator edit: format.
Best Answer01-03-2022 19:29
01-03-2022 19:29
Too bad you're having the same problem, Carabella.
I just downloaded the manual, so perhaps it will help me figure things out.
I really don't know how to use this thing, and it's even worse when I can't see the screen.
Best Answer01-03-2022 19:50
01-03-2022 19:50
Update: I found directions for how to restart my Inspire 2 -- which were:
1] Plug the USB part of the charger (Inspire attached as if to charge it, though mine was already charged) into the USB port on my computer.
2] Then I squeezed both side buttons for 5 seconds.
3] The display didn't show until I put the Fitbit back on my wrist. Tada! Now the display is working!
Problem solved!
Best Answer01-04-2022 03:43
01-04-2022 03:43
Best Answer01-04-2022 08:02
01-04-2022 08:02
Did not work for me!
