06-10-2019 09:46
06-10-2019 09:46
My inspire is almost a month old (5/12/19) and it is not responding to button pushes or screen taps/swipes. The 5 second hold while charging reset does not work.
Steps appear accurate. It seems to be tracking everything and it's syncing alright, just not responding on the device.
06-10-2019 09:50
06-10-2019 09:50
Backdoor fix: I changed the clock face and synched again. All fixed!
Not sure why it was stuck in the first place but it's working now.
03-04-2020 08:03
03-04-2020 08:03
Thank you, Sarah! This did the trick for me too. I was about to start rummaging about for warantee info. You saved me a bunch of hassle! ❤️
Best Answer04-29-2020 14:34
04-29-2020 14:34
How do I fix the clock face?
Best Answer04-29-2020 14:49
04-29-2020 14:49
> your profile picture > your device image.
05-05-2020 20:51
05-05-2020 20:51
I am unable to get beyond the Fitbit Ivón. Just changed from blue to white, after it buzzes. Nothing else
Best Answer05-28-2020 16:06
05-28-2020 16:06
Thanks for the clock-face change hack, it worked for me!
My Fitbit Inspire HR was frozen and only showed the smiley face when attempting to reset, every reset attempt failed.
I saw your post and gave it a shot. The clock-face changed and then I noticed that there was a update that never finished, I think this was the why my Fitbit was frozen.
I hooked up to the charger and I finished that update and I also updated to the latest firmware.
It's all working, thanks for passing on the info.
Best Answer01-28-2023 12:17
01-28-2023 12:17
3.5 years later and this solve still works. Thank you!!
