02-28-2022
14:38
22:51
02-28-2022
14:38
22:51
Hi, my Fitbit 2 has stopped tracking heart beat and sleep
@Clarericka one feature of the Inspire 2 is that you have the option to wear it on your wrist or on a clip. If it is set to wear on a clip, the heart rate monitoring will be turned off and the green lights won't be on.
To check this, press and hold both buttons on the sides of the device. You'll get a list of settings. Swipe up until you get to the last one. It should say "On Wrist". If it says "On Clip", tap on that and change it to "On Wrist".
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
Thanks so much. I was having the same problem and now it’s working again!
