09-04-2019
05:49
07:11
AndreaFitbit
09-04-2019
05:49
07:11
AndreaFitbit
The following message appears all the time even though I have followed all the suggestions that I have found. It is a huge bug that has not been resolved.
"Notification service not running. A phone restart is required to re-enable notifications of your tracker".
Moderator edit: format.
09-06-2019 07:25
09-06-2019 07:25
Welcome aboard @Staceysmit. I apologize for the delayed response and will be happy to assist with the notification message that appears on your Fitbit Inspire. Thank you for letting us know that you have already followed all the suggestions that you have found.
In order to assist you, could you please let me know which is your phone's model? Also could you please confirm that you have followed the instructions of help article: My Fitbit device isn't receiving notifications from my phone.
To make sure your Fitbit device syncs and receives notifications from your Android phone, open the Settings app on your phone and confirm or adjust the following settings:
I'll be waiting for your response.
Best Answer09-13-2019 04:57
09-13-2019 04:57
I am facing a similar issue on my Fitbit Inspire HR. I have tried all the suggestions on the forum, to no avail. My phone model is OnePlus 6, and I have checked the supported devices to confirm that the device is supported.
Best Answer05-11-2020 06:08
05-11-2020 06:08
I have a new phone and keep getting the same issue over and over again. "Notification service is not running. A phone restart is required to re-enable notifications on your tracker". Tried that multiple times and it didn't work. I unistalled and reinstalled the app and it worked for maybe one day. Tried every suggestion but either they don't apply or don't help.
I now have a Huawei P30 Pro.
Help! and thank you.
05-30-2020 15:33
05-30-2020 15:33
Is your Fitbit app by chance on external storage? SD card? The notification service doesn't work (or work well) if the app is on the SD card, so check to make sure the app is in your phone's internal storage.
