03-16-2019
09:44
12:01
MattFitbit
03-16-2019
09:44
12:01
MattFitbit
I just upgraded from the Alta HR to the Inspire HR. The feature I loved the most with my Alta was that I could receive a txt notification and it would show the sender’s name only and not the message. Because of this, prior to purchasing the Inspire I researched and made sure it would be the same situation if I upgraded. However, now I am setting my Inspire up and it’s showing me the sender AND a portion message. It’s hightly annoying because it seems that I can’t turn the message part off. Some of my messages discuss very private matters and having the words scroll across the screen isn’t something I want seen. This needs fixed ASAP as an upgrade to the app, not by telling me to replace my device for another one or to go back to my old one.
Moderator edit: edited title for clarity
Best Answer03-16-2019 12:11
03-16-2019 12:11
@KaLyn Thanks for the feedback regarding notifications.
Though this was an intended change to show full notifications on wrist, I think you do bring up a good point. I would recommend starting a new thread on our Feature Suggestions board. This is the best way for our team to determine which new features are implemented.
If you find yourself in a spot where you do not wish for your messages to show on your wrist for privacy concerns, you can pretty easily toggle the notifications feature on/off by holding the button down the button and tapping the 'notifications' tab.
Hope this helps! Feel free to let me know if you have any questions.
Want to get more deep sleep? Join the discussion on our Sleep better forum.
