03-31-2022
14:49
22:36
03-31-2022
14:49
22:36
Hey! I want to be able to set a running goal in km. Basically, I want FitBit to notify me once I have completed 1 km, 2km etc after having begun running. I want to learn better and think increasing the distance gradually would be the way for me. Thank you!
04-05-2022 06:05
04-05-2022 06:05
Hello @NikitaS30 and welcome to the Community. I don't use an Inspire 2, so I'm not sure if it has this feature or not. The Inspire 2 manual doesn't mention it specifically. If it exists, this is where you should find it. Open the Exercise app on your Inspire 2, then choose Run. Swipe up on the screen to get to the settings. The manual says you can set a goal. Look for a Lap option. If Lap isn't an option, then you can't get this feedback on an Inspire 2. I do know that if you set a distance goal, your Inspire 2 will vibrate when you are halfway to your goal.
Laurie | Maryland
