08-02-2022
14:39
22:14
08-02-2022
14:39
22:14
There's a gap between 1 and 3 in sleeping tracking on my Inspire 2. It was working very well but has had these gaps 4 nights over the past 2 weeks. I've had it for 2 months now. I've updated, restarted, worn tight and loose, can't find any settings to make sleep tracking accurate
08-03-2022 14:19
08-03-2022 14:19
I'm having the same issue. I just noticed a sleep sensitivity setting. I won't know until tomorrow if it helps. Anyway, go to settings, then APP settings and you'll see the sleep sensitivity setting.
