My issue has been resolved
Moderator edit: updated subject for clarity and format
Hi @Oneblackdoodle ! Thank you for you post and feedback! I'll be glad to forward it.
As you are already in contact the the Test Field Support team and to avoid confusions, I'll recommend to keep working with them.
If the steps provided by them do not work, just reply to the last message. The'll be glad to investigate you case further.
See you around
