In the Fitbit app, under exercise short cuts, I added spinning and then I synced it with my Inspire HR tracker.
Now I want to activate spinning as an Exercise so it can be tracked. Can I I activate it in my Fitbit app? Or just I only use my device?
I read that I can activate it in my Exercise App on my tracker.
However when I access that app, I see that I can have 6 different exercise types. However mine list Run and then Pilates five times. Neither of those are my exercise shortcuts!
I'm really confused. Can someone help??
Thanks!
Welcome to the forums!
You need to activate it on your device. Scroll to the exercise screen Scroll thru until you see the one you want. Press and hold button until it starts.
When done Press and hold button until it stops
Hope that helps!
Wendy | CA | Moto G6 Android
Best AnswerThis had happened to me a few times as well with the repeating Pilates ... not sure what changed but the next day my proper exercise shortcuts were there. Possible glitch? I did resync so that may have helped as well, even though I hadn’t changed anything in the app.
