10-31-2022
06:55
21:01
10-31-2022
06:55
21:01
Let's talk is 24/7. When is it available? Never acording to what I've found. This is urgent.
M. E. Shaw
Hi, @shawhotmail if you are not seeing the online chat available, that means there is no one at the time to help you. If you try again it a little while you should find it open.
However, the Community can solve many issues (other than physical damage to your Fitbit device or warranty claims). If you would like to post your question here it is likely that someone here will have some thoughts for you.
Good luck with your issue!
Best AnswerHi, @shawhotmail , I am so sorry that you have had these problems. I could try to help you with this but if you bought it for your husband in November last year, and you are having significant problems with it, then in order to make a warranty claim you really need to get in touch with them asap. The Community here may be able to help you but it is really important first for you to file a case with Fitbit Customer Support to let them know that it isn’t working - in order to protect your warranty rights. You can get in touch with them via Contact.Fitbit.com
My personal preference would be to phone and then follow up with email. Failing that contact via email very clearly laying out what is not working.
Do that first, as time may be sort given warranty expiration.
However, in the meantime, if you would like to give us an idea of what is going wrong we might be able to help - and then any warranty issue might not matter. Please always give as much information you have - what problems you see, what error messages you might have seen, whether this is a new or forever issue, and what phone / tablet you use.
Good luck!
