10-24-2022
23:10
21:01
10-24-2022
23:10
21:01
I'm trying to post a reply and it won't let me. It says to correct the highlighted fields but I don't see any highlights.
10-25-2022 16:00
10-25-2022 16:00
@booch21 , A warm welcome to the Community! Thank you for your message
Could you include the link of the thread that you wanted to reply to, so that I can get a closer look at it? Or the board you meant to post your inquiry?
I'll move your comment to stand alone thread so that we can avoid misunderstandings with the subject discussed on this thread and to keep the Community in order.
I'll be expecting your reply
Best Answer10-26-2022 07:44 - edited 10-26-2022 07:46
It was in: Inspire 2 counting steps incorrectly
Every time I try to post anything or even PM you my comment gets rejected.
If I try to include any additional information, like a link or a screenshot. it won't let me.
Best Answer10-26-2022 18:57
10-26-2022 18:57
@booch21 , Thank you for your reply and further information.
Please try clearing the cache of your browser. Seems a bit odd, that you can reply and post here but not on that thread.
Do you receive further error messages?
Let me know how it goes
Best Answer10-27-2022 09:29 - edited 10-27-2022 09:35
I cleared the cache but it didn't help. I also tried using a different browser and I still get the same messages to correct the highlighted fields (there are none). If I try and copy the other error message and paste them into this post it will reject it.
I used both Chrome and Firefox. This is exasperating!
Best Answer10-27-2022 09:45 - edited 10-28-2022 05:19
It seems to have a problem with numerals. If I take them out and spell out the number instead of using the numeric symbol, it will accept the post. Here is the error message that comes up every time:
The message body contains twenty four-eighteen, which is not permitted in this community. Please remove this content before sending your post.
I have no idea what that means.
Another error says something about me using a bad word but I didn't see any 'bad' words. I tried rewriting the post every which way, nut it still wouldn't work.
10-30-2022 18:12
10-30-2022 18:12
@booch21 , Thank you for your reply.
Please make sure your post contains plain text - you can do this by using the "Clear formatting" button in the reply tool bar.
Should the situation persists, please attach a screenshot on your reply.
Hope this helps.
Best Answer10-31-2022 04:20 - edited 10-31-2022 04:25
I'm getting a different message now:
The message body contains twenty six-zero seven , which is not permitted in this community. Please remove this content before sending your post.
Again, I had to remove the numerals and spell out the numbers in order for it to accept the sentence above.
It still won't let me post a screen shot of anything. "Clear formatting" did not make a difference.
