04-29-2020 05:58
04-29-2020 05:58
Is it possible to use a clip with the Inspire HR or only with the Inspire? I am finding conflicting information on this. I have used a One for years and love the clip method, but would like the option of wearing on my wrist as well. In your opinion, is the Inspire adequate without the heart rate feature? Can anyone comment from personal experience? Thank you in advance.
04-29-2020 05:58
04-29-2020 05:58
Best Answer04-29-2020 08:11 - edited 04-29-2020 08:39
Hi, @katgk , the clip designed by Fitbit is recommended for the Inspire only, as tests indicated that the HR version could fall out of the clip. You may be able to find a third party clip online which you could use, but do make sure it is designed to hold the Inspire HR version securely, as it is a little fatter than the non HR version.
It is perfectly acceptable to use it on your body rather than your wrist, and should continue to give you accurate step counts etc. You will get best results if you wear it on your hip or in your bra, just as you used to with the One. It would make sense to turn off the HR monitor when you are wearing it on your core rather than on your wrist.
The Inspire HR is a great choice if you would like to sometimes wear it on your wrist and sometimes on your core. If you decide you do not want to use it on your wrist afterall all then it wouod make sense to buy the basic Inspire. It was designed to be the replacement for the One, so should suit you well.
PS you posted twice, which is against guidelines, so I merged your two posts. 😉
